The x650 is prefect for my needs but having issues with.
First, I cannot get this to thing to work with any video at all. I have tried just about everything but use a custom EDID. Running dmesg | egrep 'tc35|1-1.4|uvc' & systemctl status kvmd-tc358743 shows no errors. I'm at loss what to do or use for a custom EDID for a 1280x1024 desktop resolution. The cable is good as it checks out for displaying the pi output to a HDMI monitor.
Second, enable RTC from the guide does not work when using the hwclock command. It just gives the following error "hwclock: Cannot access the Hardware Clock via any known method". I did modify the config.txt like it said to do. Not sure if RTC is related to the above video issue or not.
Any ideas?
I'm hoping to get this to work with ease as I'm trying to see if this would be an option for some servers that don't have something like an iDRAC or iLO (IPMI etc..) for remote management.
Hardware:
Vis Viva Raspberry Pi Compute Module 4 (CM4108016) (16GB eMMC);
Geekworm X650 Open Source KVM Over IP Kit PCIe Version for Raspberry Pi Compute Module 4
