need to add 2.5" SDD on my Pi 3B powered with X710 | Geekworm
  • is the X820 V3.0
    compatible with X710 ? and X820 casing ?
  • Yes — X820 V3.0 works with the X820 casing (especially the updated metal case).
    But compatibility with X710 is not confirmed. If you mean a different board by “X710,” you’ll need to compare physical layout and specs to be sure.
    Posted by Eggy Car 5 months ago!
  • Yes — the X820 V3.0 SATA board is compatible with the Suptronics X710 power HAT and it will fit the X820 cases (the official/updated metal or acrylic X820 cases). You can stack X710 + X820 on a Pi 3B, but note a few practical caveats below
    Posted by Dobrevyzvaneni Mobi  1 months ago!
