As the title says when using my Raspberry Pi 4 with X857, X872 and X735 the Wi-Fi doesn't connect to anything, I tried both 2.4 and 5 GHz, they are detected correctly but it just doesn't connect.
I tried moving closer to the router and using my phone hotspot but it doesn't change a thing.
Ethernet works flawlessly but I still need Wi-Fi.
locale and wpa_supplicant are configured correctly, I've reinstalled the Raspberry Pi OS just be sure but that didn't help.
I also tried using small monitor resolutions and even disconnect completely the monitor to rule out HDMI interferences but it didn't work.
Might be that either the X872 or the X735 are interfering with it? That would be extremely disappointing since they're also shown together in the Wiki as a working solution.
