LVDS to HDMI board: What is the purpose of two LVDS input connectors | Geekworm
  • Hello...just have a question about the two LVDS input ports on teh LVDS to HDMI board. Are they both used for input? Is on for input and the other for output? Just curious why there are two.
    Thank you.
  • Hi,
    Thanks.
    There are 2 way input.
  • @Harry Huang Thank you...just curious though as to why...are there 2 just in case one does not work? If you have two devices each with their own LVDS signal, would I plug both up to each port?
    I only have one device with LVDS, so I just plug into either one and it works...just was curious if you could use both ports at the same time with two different LVDS signals...if so, would not be sure how to switch between the both of them.
  • @Harry Huang I have the same question.  WHY does it have two inputs?  Can I hook two DIFFERENT inputs and have one output?  How do you switch between the signals?
    Thanks
