X1208 - Is there any way to trigger the PSW lik... | Geekworm's Forum
X1208 - Is there any way to trigger the PSW like I can on the X1202, X1203, & X1205?
  • I have your X1202, X1203, X1205 and X1208 as well as several X1004 boards. One of the things I love about the first three boards is the ability to remotely trigger the PSW using an optocoupler. When triggered, those boards and the Raspberry Pi 5 power up. I can also power everything off the same way using three quick pulses through the PSW connector.
    I noticed that the X1208 I received does not have a PSW connector. Is there any way to trigger the PSW like I can on the X1202, X1203, & X1205? I know I could solder some wires to the switch pins, but I don't want to void my warranty. Hoping you know of something else I could do.
    Thanks in advance.
    Bill
