X2015: CPU Overheating Detected | Geekworm's Forum
  • Internet Connection Dropping Frequently. Your fnaf Wi-Fi or wired internet keeps cutting out, making it hard to work or play online. What usually makes a CPU overheat?
  • The X2015: CPU Overheating Detected warning usually isn’t directly caused by your internet connection dropping. It’s more likely a hardware or cooling issue. Internet instability wouldn’t normally overheat a CPU.
    Common causes of CPU overheating:
    • Dust buildup blocking airflow inside the case
    • Failing or slow CPU fan
    • Dried or poorly applied thermal paste
    • Poor ventilation (laptop on bed/soft surface)
    • High background CPU usage (check Task Manager)
    • Overclocking (if enabled)
    If your internet keeps cutting out, that may be a separate issue — possibly a Wi-Fi adapter driver problem or the system throttling performance due to overheating.
  • Take it to a repair shop, bro, or at least get the cooling fan fixed.
    level devil - not a troll game
  • If the internet is also dropping frequently, it could be a separate network issue rather than being directly related to the CPU. Monitoring temperatures and checking the cooling system would be a good first step before troubleshooting the network connection.
    free top games
