- X2015: CPU Overheating Detected
Internet Connection Dropping Frequently. Your fnaf Wi-Fi or wired internet keeps cutting out, making it hard to work or play online. What usually makes a CPU overheat?
2
Posts166
The X2015: CPU Overheating Detected warning usually isn’t directly caused by your internet connection dropping. It’s more likely a hardware or cooling issue. Internet instability wouldn’t normally overheat a CPU.
Common causes of CPU overheating:
• Dust buildup blocking airflow inside the case
• Failing or slow CPU fan
• Dried or poorly applied thermal paste
• Poor ventilation (laptop on bed/soft surface)
• High background CPU usage (check Task Manager)
• Overclocking (if enabled)If your internet keeps cutting out, that may be a separate issue — possibly a Wi-Fi adapter driver problem or the system throttling performance due to overheating.
