can i use a x1009 and 1 or 2 x-ups1 | Geekworm
  • hi i am asking if i could use rpi5 16gb to make a nas with built in battery like
    x1009 with 5 sata ssd a raspberry 5 16g  with 1 or 3 x-ups1
    the x-ups1(s) would be to run the nas atleast 30 min to 1 hour in case of power failure
    I know the x1009 needs 12v about 10amps or less to run 5 2.5 inch sata ssd
    and usp1 can only poduce 12v 3amp i also found a 12v 12amp psu that might power setup
  • You can stack multiple X-UPS1s to increase the current
    • Takes 12V input, delivers SATA power + data to SSDs.
    • Needs up to 10A (120W) depending on SSDs and peak usage.
    • Compatible with Raspberry Pi via USB 3.0 or PCIe (depending on version).
    • wacky flip
