X735 Power Button Script and Booting from USB
I have a question regarding setup of X735 power button script when combined with booting from USB. I may already know the answer but want to ask first.
I tried setting up computer to boot from USB (I have X872 shield component with NVMe SSD). I used the steps on Tom's Hardware and this works fine. But when I set up power button script for momentary switch in the case (I have X857-C1) it does not work completely. Turning on and powering off works. Rebooting using button or software fails. I see a message on startup that the SD card cannot be found and the system enters a 20 second cycle to try booting again which also fails. Only way to start computer is to completely power off and power on.
I am wonder if I should set up power button on SD card first; then perform steps to boot from USB. The script for power button was written before code that enables booting from USB.
Please give me feedback. I will try what I described in the meantime and update results.
Thanks
