I've added the jumper for the auto power on function and my pi 4 now reboots just fine. I'm having an issue with starting the pi after a full shutdown. The pi does not want to start after being shut down with the x750 hooked up, reboot works fine though. I either have to hold down the power button for like 10s and then turn it on, which doesn't always work.
I have to unplug the x750's power supply(the x750's power supply is the only power I'm currently using, no batteries, though I have them ready), then plug the x750's power supply back in, then it'll power on if I do that.
Otherwise the pi doesn't even try to power on, not even a flicker from the leds on the pi. I'm not sure if this this issue is because of the script, or an OS issue, or something else. When I run the script there is no output in the terminal when I follow the instructions in the wiki
uname -a outputs
"Linux raspberrypi4 4.19.97-v8+ #1294 SMP PREEMPT Thu Jan 30 13:27:08 GMT 2020 aarch64 GNU/Linux"
