X708 software shutdown is not safe, X708 cuts the power before shutdown is completed
Hi! I’m using X708 v2.0 uninterruptible power supply expansion board with Raspberry Pi 4 (Raspbian Buster 11.9, Linux 6.1.21-v8+ aarch64), with the latest X708-script from github installed, all system components are up to date.
When I use X708 on-board button to shutdown, Raspberry Pi shutdowns firmly and gently, and then X708 cuts the power.
If I use software shutdown (“x708off” command, which is the alias to “xSoft.sh 0 13”), then X708 cuts the power before Raspberry Pi shutdown (almost immediate).
Expected shutdown behaviour using “x708off” command is the same as pressing hardware button on top of the X708 HAT - X708 should wait while Raspberry Pi performs safe shutdown and then cut the power.
Does anybody have the same observations? It is a bug or a feature?
Kind regards
