LVDS2HD macbook issue
Hi, I bought an LVDS2HD board:
https://geekworm.com/products/lvds2hd I connected it to my MacBook motherboard (from a non-Retina model with a Full HD LVDS display), but it isn’t working.
At first, I thought there was a problem with the connection. However, I bought an HDMI2LVDS adapter for this display panel, connected it to the LVDS2HD board, and everything worked fine. With the signal from the MacBook, though, it still doesn’t work.
I’ve tried all the steps on the wiki page, but I still only get a black screen.
Here is the debug log I obtained:
UART init 115200 8n1. IT6263+ STM8S005, HDMI, with Audio. Firmware is programmed by QQ2073196958. 2025-01-04 IT626X_BASE_M1_MYSON_V114 OP1=0, OP2=1, OP3=1, OP4=1, OP5=1, OP6=1. Bits =0, Ports=1, Mapping=1, Audio=1, Swap=0. IT626X is detected! Init as HDMI_1080p60. Application start. AV_Mute 9: lvds unlock,==========Set AV Mute============ AV_Mute 9: lvds unlock,==========Set AV Mute============ AV_Mute 9: lvds unlock,==========Set AV Mute============ AV_Mute 9: lvds unlock,==========Set AV Mute============ Reset LVDS PCLKErrorCnt found =1 InputPclk =360 LastInputPclk =0 AV_Mute 6: Input timing unstable: ==========Set AV Mute============ ==================reset video===================== Error, HTotal = 1, VTotal = 1 Error, H_Active0 = 4007, V_Active0 = 1046 InputPclk =360 **SSCPFIFO overflow** AV_Mute 6: Input timing unstable: ==========Set AV Mute============ ==================reset video===================== Error, HTotal = 2080, VTotal = 1201 Error, H_Active0 = 1920, V_Active0 = 0 InputPclk =358 **SSCPFIFO overflow** AV_Mute 6: Input timing unstable: ==========Set AV Mute============ ==================reset video===================== Error, HTotal = 2080, VTotal = 1201 Error, H_Active0 = 1920, V_Active0 = 0 InputPclk =360 **SSCPFIFO overflow** AV_Mute 6: Input timing unstable: ==========Set AV Mute============ ==================reset video=====================
