X857 with 2TB on Raspberry Pi 4 | Geekworm's Forum
  • Hi
    I do have an Issue with Raspberry Pi 4/X857 unsing a 2TB mSATA Disc:
    I did the normal installation-process:
    I have not yet tested if the mSATA would still work if i connect it directly to a PC without the X857 (i lack a sata to msata converter).
    But basically:
    Can it be that X857 does not support 2TB mSATA (specialy the used disc) or is the mSATA disc broken?
  • Hi,1/Please use a USB cable instead of the USB connector to test it.  Confirm whether it is a problem with the connector.
    2/please connect the x857 to the PC , if the device can be found.   please test with another mSATA SSD, or test your 2TB mSATA separately.
  • I interpret your answer to mean that the 2TB disc should actually work with the X857 V2. I have therefore test the disc directly connected to a PC. In fact, it seems to be a disc problem. the disc even did not work directly connected to pc.
    Thanks anyway for the Support
  • You are welcome.  If any questions, please feel free to contact us.
    Best regards
