eMMC Flashing Difficulty on X651 | Geekworm's Forum
  • Posting this information here in case someone else runs into the same problem.  I just bought an X651, and a CM4 with eMMC flash.  I had a lot of trouble flashing the eMMC with my Linux PC.  The process would always timeout and the kernel log would show USB bus resets.  I tried several different power supplies, USB cables, and different PCs.  What seemed to work for me was changing how I ran the rpiboot utility.  Specifically following their readme worked:
     git clone --recurse-submodules --shallow-submodules --depth=1 https://github.com/raspberrypi/usbboot
     cd usbboot
     make
     sudo ./rpiboot -d mass-storage-gadget
    On my earlier attempts, I had not done a recursive git clone, and I was only running 'sudo ./rpiboot'.  After following the above instructions, the RPI imager showed the device as "mmcblk0 Raspberry Pi multi-function USB device" instead of "RPI-MSD -0001".  This allowed me to flash the device quickly and reliably.
    Hope this hels someone else.
  • It helps me a lot. Many thanks.
    free online games
  • Good catch. In my experience, when the CM4 appears as `RPI-MSD -0001`, flashing can be hit-or-miss depending on the host system. Using the full rpiboot setup with the required submodules often resolves detection and stability problems.
  • Driving directions contribute to smoother transportation by offering route optimization and practical navigation tools. Users can travel with greater certainty and spend less time dealing with navigation challenges.
