Will it fit?? | Geekworm
Will it fit??
  • Hi Geekworm!!,
    I have a Raspberry Pi setup that has a Back-mounted PCIe 3.0 Switch to dual M.2 hat for Raspberry Pi 5 (Seeed Studio) with an SSD and a Hailo 8 Accelerator with Heat Sink attached to the M.2 hat. I’m wondering if the Geekworm X1205-C1 or X1200-C1 can accommodate the heat sink with the right stand offs. I think I need approx. 23-25mm of room below. Are the provided stand offs enough to get the PI aligned with the case?
  • @aowolabi Hi, the X1205-C1 or X1200-C1 can not accommodate the heat sink with the right stand offs. The heatsink is too thick, the board ports can't align with the cases if you use the heatsink. Thanks for your understanding!
  • @Cindy Ding thanks for your response, out of curiousity how tall are the  Pi 5 X1205 UPS shields?
  • @aowolabi Hi, the distance/height from Pi 5 to the X1205-C1 case bottom is 31.1mm. Please refer to the below photo.
