x710 x100off script and safe shutdown do not work with jumper 1-3 on | Geekworm
  • Hello
    Pi2b + OS Buster last version + last fixes
    X710 script installed
    Jumper on 1-3 for automatic boot after power recovery
    Problems: it does not work with jumper set in 1-3:
    1/ x710off does not work: it displays "X710 Shutting down" but it don't do it
    2/ when pressing i.e. 4s on the button, it does not go to safe shutdown, no slow blinking
    3/ when powering up with DC jack, the fan starts, the pi boots, but the led blue remains off. I presume it shall be
    4/ by pressing 1-2s, it does not reboot with rapid blinking
    but, with the jumper 1-3 off: everything runs perfectly, incluing script.
    Thank you
  • Sorry my Pi is a PI 3 B and not 2B
  • Hi, 'AUTO ON' mean the x710 will AUTO POWR ON when the AC main power supply is connected, so the external switch is disable when 'AUTO ON'
    I was not talking  about external switch but the PCB switch . it simply does not work
    Tx
  • I am having a similar issue. I don't have any jumpers on the function header. I have the external momentary switch connected. I can power on or hard power off, the reboot and soft power down do not work.
    I am unable to install the software, not that I should need to as I am not trying to power down through the software.
  • @Thomas P
    Hi, when AUTO ON is enabled, the safe shutdown function no longer works.
    Regards,
  • We will update the X735 on the next bulk, will solve this question.
  • thanks
