python libgpiod - GPIOD - Event Callback | Geekworm
    Does anyone able to share how to write a callback event on falling edge on an Input GPIO. I can't find any example on how the lib handle event instead of using pulling method to find falling event.
    Please helps.
  • Hello, you can refer to the following sample.
    #!/usr/bin/env python
    import gpiod
    import time
    # Define the chip and lines
    chipname = "gpiochip0"  #Please use gpiochip0 if using Raspberry pi 4/3 hardware
    # chipname = "gpiochip4"  #Please use gpiochip4 if using Raspberry pi 5 hardware
    line_offset = 6
    # Open the GPIO chip
    chip = gpiod.Chip(chipname)
    # Get the input line
    line = chip.get_line(line_offset)
    line.request(consumer="my_program", type=gpiod.LINE_REQ_EV_BOTH_EDGES)
    def print_event(event):
        if event.type == gpiod.LineEvent.RISING_EDGE:
            print("---AC Power Loss OR Power Adapter Failure---")
            print("Shutdown in 5 seconds")
            time.sleep(5)
        elif event.type == gpiod.LineEvent.FALLING_EDGE:
            print("---AC Power OK, Power Adapter OK---")
    try:
        # Wait for events indefinitely
        while True:
            event = line.event_wait()
            if event:
                event = line.event_read()
                print_event(event)
    except KeyboardInterrupt:
        print("Exiting...")
    finally:
        chip.close()
