OLED on x729 | Geekworm's Forum
OLED on x729
  • Hi all
    I am facing problem in installing OLED. Here is one of the example:
    amps_pi5@raspberrypi:~/oled $ sudo pip3 install --upgrade setuptools
    error: externally-managed-environment
    × This environment is externally managed
    ╰─> To install Python packages system-wide, try apt install
        python3-xyz, where xyz is the package you are trying to
        install.
        If you wish to install a non-Debian-packaged Python package,
        create a virtual environment using python3 -m venv path/to/venv.
        Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
        sure you have python3-full installed.
        For more information visit http://rptl.io/venv
    note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
    hint: See PEP 668 for the detailed specification.
    What should I do?
    Here is my pi OS version.
    PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
    NAME="Debian GNU/Linux"
    VERSION_ID="12"
    VERSION="12 (bookworm)"
    VERSION_CODENAME=bookworm
    ID=debian
  • Is the OLED displaying normally? If it is, you can ignore the hint.
