Hello, I'm new to Raspberry and I have a question:
With this box geeksworm v2.0
https://geekworm.com/products/geekworm-naspi-2-5-sata-hdd-ssd-kit-for-raspberry-pi-4-model-b
To correctly use the fan as well as functions related to the power supply, there is a script to install.
I'm planning to get this Raspberry kit: https://www.kubii.com/fr/raspberry-pi-4-modele-b/3011-starter-kit-raspberry-pi4-4gb-3272496302112.html
I want to use it for a home automation box with home assistant OS
To install the script, can I install Raspbian first, then install the script and then install home assistant OS?
Or I can directly install Home Assistant OS on the SSD connected to the PI and set up the script using a docker container?
Thanks for your help.
