AtGames Legends Ultimate
Has anyone been successful using the LVDS to HDMI adapter on the 1.1 Cabinets? I have had no luck but not sure if its the monitor I'm using, i tested both a 23" Asus VH236H and an LG 27GN850-B. I connected at first just the lvds cable provided by geekworm from the cabinet board to the adapter. Then from the adapter HDMI to the Monitors mentioned above. I got no HDMI signal on both. I then left everything as is and also connected the factory monitor to the lvds adapter board and the factory monitor worked but the HDMI still no signal. Not sure if i need to adjust anything on the jumpers but i left them as default.
