X728 and Rpi4 - IOError: [Errno 121] Remote I/O... | Geekworm's Forum
X728 and Rpi4 - IOError: [Errno 121] Remote I/O error
  • Hi
    Running:
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    Fresh hardware install, following GUIDE from https://raspberrypiwiki.com/X728-Software
    Jumpers: PLD
    Step: 6 outputs:
    pi@raspberrypi:~ $ sudo python x728bat.py
    Traceback (most recent call last):
      File "x728bat.py", line 31, in <module>
        print "Voltage:%5.2fV" % readVoltage(bus)
      File "x728bat.py", line 11, in readVoltage
        read = bus.read_word_data(address, 2)
    Why?
    EDIT: On first post i used a Rpi4B
    On the same OS, on a Rpi3 it works!
    So, how to make it work on the Rpi 4 then ?
  • @li xia
    Yes, as i mentioned in first post. I followed the guide on two Rpi4s.
    Only the Rpi3 worked.
