Hi all,
Is the Geekworm X306 V1.3 18650 UPS Expansion Board compatible with those 2 boards? In particular with the E version with the POE hat? (Yes, in this case battery will not be charged by POE)
Hi all,
@Jaime Nebrera
Hello
Don't try to use X306 on the two boards you mentioned, because X306 uses pogo pins to power the Raspberry Pi zero 2w, and the pogo pins need to touch the welding pads on the Pi 2W corresponding PCB board.
The Geekworm X306 V1.3 18650 UPS Expansion Board is generally compatible with Raspberry Pi boards, including those with a PoE HAT, as long as there is enough physical space for both. However, since the PoE HAT uses the GPIO pins for power, you may need to ensure that the UPS board and PoE HAT do not have conflicting power delivery mechanisms. If you're not relying on PoE for charging, it should work, but you may need to use GPIO stacking headers or a different mounting configuration to fit both components properly. Monkey Mart Game
