Geekworm PSE30G 30W Gigabit PoE Injector IEEE 802.3af/at Compliant PoE Power Supply
Geekworm X1500-C1 Metal Case for Raspberry Pi CM5 and X1500/X1501
5-Pack 7Pin SATA-III 6Gbps Data Cable for Hard Drive/X1009 (50cm)
Geekworm 30W PoE Splitter 12V 2.5A Output IEEE 802.3at Standard for X1202/X1206/X1205/X729/X1010
Geekworm X1501 CM5 IO Carrier Board for Raspberry Pi Compute Module 5 Support 1GbE+2.5GbE/Dual M.2 NVMe SSD
Geekworm X1500 CM5 IO Carrier Board for Raspberry Pi Compute Module 5 Support 1GbE/Dual M.2 NVMe SSD
is the X820 V3.0
compatible with X710 ? and X820 casing ?
