Gemini NASPi - RAID0/1 verify
Hi all,
I've recently set up a 3.5" RAID1 board, OS is installed, RAID switch is set, partition is formatted and I can use the drive as I wish.
I'm using Raspbian OS Lite 64 bit + Openmediavault , and I can see only the /dev/sda as expected.
I've experienced an issue for now, where the /dev/sdb is now presented by the OS (fdisk -l ), and there's no content in it in terms of files and directories. I did a reboot and the drive was back to /dev/sda with the content in.
So, behaviour a part, I am concerned about the RAID1 process, as I believe is not working. How can I verify that?
Board scripts are installed and working.
