NASPi + PoE? | Geekworm's Forum
NASPi + PoE?
  • Hello,
    Do you have a version of X735 that takes power from PoE?
    I would like to build a Pi appliance that has a SSD/HDD, hard-wired to home network and is powered through PoE. NASPi case looks great however it doesn't look like X765 and X735 are compatible. Can you suggest a solution?
    Thank you
  • Or, can I add X765 to use with X-C1 in NASPi?
  • Can I use X765 with X857-C3 case (and X857-V2)? Will the power button work?
  • Hello,friend
    Sorry, NASPi does not support x765 POE board. and there is no metal case for x765 now.
  • A PoE splitter that splits the Ethernet and power signals is an option. While the Ethernet connection is utilized for network connections, the PoE splitter will separate the power from the Ethernet cable and supply a separate 5V power source for your Raspberry Pi. The Raspberry Pi and other connected devices can then be powered using the X735 power management board immaculate grid
