KVM-A3 0.96" OLED Display is dead | Geekworm's Forum
  • Recent purchase of KVM-A3 device, set it all up with a downloaded OS.  Everything seems to be working ok, and I can view and control a PC connected to KVM-A3, the only issue us that the 0.96" OLED display is dead, never lighting up.  Any idea why this might be?
    Display is inserted correctly into connector and screwed into place.
  • Found some information and got it working:
    Set file system to read/write with
    rw
    Added this to /boot/config.txt:
    dtparam=i2c_arm=on
    Then did this:
    echo i2c-dev | sudo tee /etc/modules-load.d/i2c-dev.conf
    Then enabled kvmd-oled with this:
    systemctl enable --now kvmd-oled
    Then set file system back to read only, and rebooted:
    ro
    reboot
    OLED now working.
  • @ deer adventure
    If the KVM-A3 itself is working fine but the OLED never powers on, it could be a firmware/config issue rather than a bad connection. A couple things to try:
    • Make sure you’re on the latest firmware for the KVM-A3 (some earlier builds had display bugs).
    • Double-check the ribbon orientation in the socket – even if it feels seated, flipping/reseating can help.
    • If it still doesn’t light up at all, the OLED panel itself may be defective and you might need a replacement.
