X728 Pi4 RTC not working
I purchased the X728 ups hat to be used with a Pi 4.I am having issues with RTC.I'm running Ubuntu Server 20.04.To rule out issues as my fault, here is what I did:- in /boot/firmware/usercfg.txt i have added:- dtparam=i2c_arm=on- dtoverlay=i2c-rtc,ds1307ls -l /dev/i2c*
crw-rw---- 1 root i2c 89, 1 Apr 1 2020 /dev/i2c-1ls -la /dev/rt*
lrwxrwxrwx 1 root root 4 Apr 1 2020 /dev/rtc -> rtc0
crw------- 1 root root 248, 0 Apr 1 2020 /dev/rtc0sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --sudo hwclock -v
hwclock from util-linux 2.34
System Time: 1608303236.603336
Trying to open: /dev/rtc0
Using the rtc interface to the clock.
Assuming hardware clock is kept in UTC time.
Waiting for clock tick...
ioctl(4, RTC_UIE_ON, 0): Invalid argument
Waiting in loop for time from /dev/rtc0 to change
hwclock: ioctl(RTC_RD_TIME) to /dev/rtc0 to read the time failed: Connection timed out
...synchronization failedsudo dmesg | grep -i rtc
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:A4:B5:B5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 net.ifnames=0 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
[ 1.861664] hctosys: unable to open rtc device (rtc0)
[ 2.460567] rtc-ds1307 1-0068: registered as rtc0
[ 25.962250] rtc-ds1307 1-0068: read error -110
[ 26.986155] rtc-ds1307 1-0068: read error -110
[ 35.562185] rtc-ds1307 1-0068: read error -110
[ 36.586157] rtc-ds1307 1-0068: read error -110
[ 37.610264] rtc-ds1307 1-0068: read error -110
[ 52.138424] rtc-ds1307 1-0068: write error -110
[ 53.162442] rtc-ds1307 1-0068: read error -110The TTY is also getting flooded with:i2c-bcm2835 : i2c transfer timed outrtc-ds1307 1-0068: write error -110Is this a bad board?Please advise.
