X825 5V connectors which to use? | Geekworm's Forum
  • Hello,
    i want to power my X825 from a 5V power board and would like to avoid to connect anything to the barrel connector (to save space - the power board will be placed inside the case).
    I read in the wiki, that the x735 should be connected the 5V connector on the board, which is next to the barrel connector. The x710 on the other hand should be connected to the 5V connector on the rear side of the board.
    Which connector should i choose? And what is the purpose of the two connector?
    Best
    Christian
  • Hi, Please refer to the following picture:
  • Thank you!
