Radxa 3W or Rada 3E | Geekworm
Radxa 3W or Rada 3E
  • Hi all,
    Is the Geekworm X306 V1.3 18650 UPS Expansion Board compatible with those 2 boards? In particular with the E version with the POE hat? (Yes, in this case battery will not be charged by POE)
  • @Jaime Nebrera
    Hello
    Don't try to use X306 on the two boards you mentioned, because X306 uses pogo pins to power the Raspberry Pi zero 2w, and the pogo pins need to touch the welding pads on the Pi 2W corresponding PCB board.
