I am trying to combine the X750 UPS on a Raspberry 4 B along with an adafruit 3.5" touchscreen. An issue is that both devices use GPIO 18 and a couple of more pins. I have changed the scripts but it appears that the X750 may have a hardwire connection to the GPIO 18 for shutdown. I do not use for that purpose so may try to physically disconnect it from that pin but wanted to know if anyone has run across this issue and has a workaround.
Thanks
