I had both of these working fine, built a raid mirror, modified FSTAB to make sure the array booted everytime and got the root account is locked error. Attempts to repair failed so I reloaded the operating system to try again and the pi only sees one drive sda, no sdb. After trying several different things, including checking both HD lights were blue on X883. I swapped drives on X883 to still only have sda showing up. Most things suggest a dead drive nut after ruling that out, I'm stumped beyond a possibility that X883 has failed.
X883 + X735 issues
Hello,
Sorry for the inconvenience.
Please test X883 without X735, please use USB cable to test HDD1, HDD2 respectively.
Could you please send us some test videos?【support@geekworm.com】and tell us your order No. Thanks!
regards
Lisa
@Lisa ZHANG So I ordered a replacement from Amazon that finally arrived. I reassembled the new unit and still have the same problem. Do you think it is worth reloading Raspian and trying again?
Could you please provide more test details and end some pictures or videos? Thanks
@Lisa ZHANG I don't have the equipment to take a video but I can tell you that I formated one drive and labeled it so that I could tell after switching locations if it was a drive issue or if there is some sort of communication issue either between the USB3 ports and the HDD or something with the board. After labeling it I swapped drives and it only sees the non-formated drive.
@Lisa ZHANG I removed the X735 and still have the same results. Only one drive shows up. Below is an fdisk -l readout
$ sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk0: 366.82 GiB, 393870311424 bytes, 769277952 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x59d6f9f3Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/mmcblk0p2 532480 769277951 768745472 366.6G 83 Linux
Disk /dev/sda: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: 2115
Disklabel type: dos
Disk identifier: 0xe0cf0292Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 3907028991 3907026944 1.8T 83 Linux
@Lisa ZHANG Interesting new development, the one drive is showing up like a usb drive now.
