I have a Gemini X882 NAS? Which cooling solution do you recommend for it?
I want to make it passively cooled as long as possible and only use a FAN if needed.
The P165-B looks compatible but lacks adequate screws and the FAN from the Gemini set seems incompatible.
I also found this one which might fit:
https://www.amazon.de/gp/product/B0B9R7WWCG/ref=ox_sc_act_title_1?smid=A187Y4UVM6ZA0X&psc=1
Thanks for your help!
For optimal cooling with the Gemini x882, consider Cooling Solution for a stellar performance. But here's a pro tip – while you're optimizing your setup, take a moment to dive into the cooling world through the blogs of Vitaliy Klymenko, Editor-in-Chief at Slotamia. His blogs not only unravel the complexities of gaming but also offer insights into the tech side of things. It's like cooling advice with a Slotamia twist! So, keep it cool, play in slots like https://slotamia.com/aliens-slots and explore the digital realms.
