【Geekworm NASPi 2.5" SATA HDD/SSD Kit for Raspberry Pi 4 Model B】
In order to better perfect and improve [NASPi], We hope to hear the suggestions and feedback of every customer. Welcome to leave us a message. Look forward to your participation.
Very nice and sleek looking solution.
While assembling i bumped into 2 issues;
1- Leave a bit of room for a cooling block (or build it included in the fan bracket)
2- There is no opening for the pi camera flatcable. I know it is developed as a NAS, but in my setup it also needs to include that camera. The flatcable barely fits above the USB2 opening on the back. If you leave a tiny bigger opening above that, or between the cover and the case, it would not interfere with looks, but be very practical.
@Bas I Hello,
Thanks for your valuable advice.
1/Our initial design is an ultra-thin and compact case. Considering the thickness of the aluminum radiator, we need to increase the height of the NASPi case, so we only keep the fan cooling scheme. The fan can provide enough heat dissipation.
2/Camera cable interface: We will seriously consider this issue. Thank you very much.
