Hello
X828 attached to Pi 3, powered by X710. works. HDD works fine
but none USB 3 port works with Flash dongle or 3G dongle when plugged in X828 (LSUSB does not detect anything).
But works ok when directly plugged in PI
Please help
Thank you
try to use USB 2 port to Flash dongle or 3G dongle?
It's doubtful that your wifi adapter can handle the higher speeds offered by faster ports. In fact, Windows will notify you if you plugged in a device that may benefit from a speedier connection. In a perfect world, you would just plug them in and all ports would be capable of handling all speeds. bad ice cream.
