Hi Just let you know, I had a pimoroni shield fpr a ssd but wanted it in a box, so brought from amazon the Geek shield and the case, as the ssd and Pi was working with the pimoroni shield all I did was swapped everything over to the X1001 and powered it up all worked so I shut down and put everything into the box it is also fitted with the cooler and fan and I also squeezed in the little save settings battery. So much better than having everyting exposed I had tried the Argon case but I could not get it to work. So Thanks Geekworm. Very Happy.
Dave
