Just have got the pikvm-a8 | Geekworm
  • biuld it based on the howto video
    but it is not working.
    the video is not detcted.
    is there a way to show if the capture device is working.
    the other cracy thing is the pacakge looked used when i got it from amazon.
    it looks like the X630 HDMI to CSI-2 has a problem the led on the device in always red.
    wfg
    Mario
  • [ 12.974083] mc: Linux media interface: v0.10 [ 13.013149] videodev: Linux video capture interface: v2.00 [ 13.036612] i2c_dev: i2c /dev entries driver [ 13.046317] systemd-journald[250]: Received client request to flush runtime journal. [ 13.073233] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 13.412943] iproc-rng200 fe104000.rng: hwrng registered [ 13.423072] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 13.424252] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 13.439046] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned. [ 13.452426] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 13.461081] rpivid feb10000.codec: Device registered as /dev/video19 [ 13.480241] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 13.481385] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [ 13.509980] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [ 13.531466] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 13.539112] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 13.547165] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 13.547769] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [ 13.559119] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 13.568152] i2c i2c-22: Added multiplexed i2c bus 0 [ 13.577728] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [ 13.585705] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 13.596403] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 13.599153] i2c 10-000f: Fixing up cyclic dependency with fe801000.csi [ 13.612228] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [ 13.613832] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [ 13.631069] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [ 13.641135] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [ 13.652739] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [ 13.655966] tc358743 10-000f: Consider updating driver tc358743 to match on endpoints [ 13.670994] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [ 13.680609] bcm2835-codec bcm2835-codec: Device registered as /dev/video18 [ 13.688617] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx [ 13.698551] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 13.698656] bcm2835-codec bcm2835-codec: Device registered as /dev/video31 [ 13.716198] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image [ 13.721986] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 13.731067] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20 [ 13.758572] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21 [ 13.771625] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22 [ 13.783729] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23 [ 13.794093] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [ 13.803980] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [ 13.813443] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [ 13.823332] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [ 13.847269] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [ 13.847724] tc358743 10-000f: tc358743 found @ 0x1e (i2c-22-mux (chan_id 1)) [ 13.866248] brcmfmac: F1 signature read @0x18000000=0x15264345 [ 13.873560] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 13.889667] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2 [ 13.890855] i2c i2c-22: Added multiplexed i2c bus 10 [ 13.892308] usbcore: registered new interface driver brcmfmac [ 14.022335] rtc-pcf8563 1-0051: pcf8563_write_block_data: err=-121 addr=0e, data=03 [ 14.031245] rtc-pcf8563 1-0051: pcf8563_probe: write error [ 14.037375] rtc-pcf8563: probe of 1-0051 failed with error -5 [ 14.052057] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [ 14.058670] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: ,errors=remount-ro. Quota mode: none. [ 14.116708] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 14.126789] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [ 14.142360] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60 [ 14.148492] Bluetooth: Core ver 2.22 [ 14.159912] NET: Registered PF_BLUETOOTH protocol family [ 14.165811] Bluetooth: HCI device and connection manager initialized [ 14.172750] Bluetooth: HCI socket layer initialized [ 14.178146] Bluetooth: L2CAP socket layer initialized [ 14.183665] Bluetooth: SCO socket layer initialized [ 14.295182] EXT4-fs (mmcblk0p4): orphan cleanup on readonly fs [ 14.303740] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: ,errors=remount-ro. Quota mode: none. [ 19.234352] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay) [ 19.245081] bcmgenet fd580000.ethernet eth0: Link is Down [ 20.808989] Mass Storage Function, version: 2009/09/11 [ 20.814569] LUN: removable file: (no medium) [ 20.828816] dwc2 fe980000.usb: bound driver configfs-gadget [ 23.437384] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 23.446248] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 23.542826] EXT4-fs (mmcblk0p2): re-mounted. Opts: ,errors=remount-ro. Quota mode: none. [ 23.887420] EXT4-fs (mmcblk0p2): re-mounted. Opts: ,errors=remount-ro. Quota mode: none. [ 26.067971] EXT4-fs (mmcblk0p4): re-mounted. Opts: ,errors=remount-ro. Quota mode: none. [ 26.410282] EXT4-fs (mmcblk0p4): re-mounted. Opts: ,errors=remount-ro. Quota mode: none. [ 36.317290] cam-dummy-reg: disabling [ 58.365889] systemd-journald[250]: Oldest entry in /run/log/journal/6817026af9334cf4b81422dc2f45c090/system.journal is older than the configured file retention duration (1month), suggesting rotation. [ 58.383954] systemd-journald[250]: /run/log/journal/6817026af9334cf4b81422dc2f45c090/system.journal: Journal header limits reached or header out-of-date, rotating. [ 275.267574] use of bytesused == 0 is deprecated and will be removed in the future, [ 275.275201] use the actual size instead.
  • found the culprid it was the included 30cm hdmi cable that had the problem. after using a different cable everything is working.
BACK TO TOP
